Connecting ProjectWise to FME
gis.analyst
Forum|alt.badge.img+4
I am going to read Data from ProjectWise. FME could read Folder trees (as attached picture) but accessing to folders is not possible. (my user name and passsword are correct)
(Also I have the Bentley CONNECTION Client installed and logged in.)
The IT guys said that they useAPI version 2.8.
Is there any solution to solve this issue?
Thanks in advanced
 About.aspx Data_InteropProjectWiseLoginProjectWiseLoginTreeFolders2ProjectWiseLoginError
Best answer by nampreetatsafe
@gis.analyst​ are you by chance trying to login in using Bentley's Identity Management Service (IMS) authentication? If so, I just learned that Bentley's API (which FME uses) doesn't support IMS Authentication.
  • June 22, 2023
That's a weird and unexpected error, I'm using this transformer quite a lot and I've never had this issue. I can freely browse into folder and select files, etc. Perhaps you need to verify the user permissions on Projectwise.
nampreetatsafe
Forum|alt.badge.img+12
@gis.analyst​: if you still haven't resolved this error, please feel free to reach out to Esri Support (since it looks like you are using the Data Interoperability extension shipped with ArcGIS). If you have a full license of FME via Safe Software, feel free to submit a support case with us here: https://community.safe.com/s/submit-case
nampreetatsafe
gis.analyst
  • July 10, 2023
Yes, I could login Bentley IMS.
From my understanding, Unfortunately bentley IMS Authentication does not work on FME product .
