Can't connect to G3 Smallworld using the SBS Plugin for Smallworld in FME.
  • August 23, 2023
  • 139 views
laurentp
Forum|alt.badge.img+8
I am working as a consultant for Consortech Solutions and I have a client who is trying to make his G3 Smallworld connection work in FME using the SBS Plugin for Smallworld. Unfortunately, the reader in FME doesn't work all the time. When it fails to show the table to choose from for reading data using the SBS plugin for Smallworld reader, the error message returned is "Bad or Invalid License for feature: spatialbiz_read [-12]". What's weird is that sometimes he is able to read his data in FME using that same reader but sometimes it fails to read the data.
Is that something people have experienced in the past and if so, is there a way to solve this issue?
Best answer by laurentp
Hello, we found the solution to the problem:
We added the HostID to the license file on the client side.
j.botterill
Forum|alt.badge.img+54
  • August 24, 2023
Hi laurentp, according to SPATIALBIZ installation documentation FlexErrors
  • Check that the version of FlexLM is compatible with your FME version.
  • Does your license server also act as an FME license server?
Launch LMtools on the license server
SBS license serverCheck the servicename = SBS license server has the correct paths. Save if changes and restart service
Then perform a status enquiry on SBS (and FME licenses)....
PerformStatusEnquiryDoes the enquiry specify more about the error.
laurentp
  • August 30, 2023
