Read all layers published to Portal
  • November 21, 2023
  • 278 views
marta.podsiad
Forum|alt.badge.img+9
I would like to read all the layers published to Esri Portal/Enterprise that are shared with particular group.
I use Esri ArcGIS Portal Feature Service
In the Parameters I would like to change the Feature Service so instead of reading one layer will read all layers from that group; A9 WTC in this case
nielsgerrits
Forum|alt.badge.img+64
If I understand correctly what you want, this is how I do it:
  • ArcGISOnlineConnector to list all items in a group.
  • AttributeCreator to create an Attribute FeatureService
    • @Value(GroupName)/@Value(_name)(@Value(_id))
  • Use a FeatureReader (Esri ArcGIS Portal Feature Service), use the attribute FeatureService in the field Feature Service.
marta.podsiad
  • November 21, 2023
It works. Thank you very much
