Looking a way to manipulate neighbour(s) pixel colors/values in a raster!
  • June 20, 2022
  • 47 views
Hello everyone! I'm new FME-User and this is my second month of learning FME. I've been fooling around mainly with maps (TIFF,JP2000) and Lidar.
I'd like to build a 3D-Model from a part of a forest where I add tree.obj for each tree in a raster.
I'm trying to build a tree detector that makes a shapefile of the border of the trees and maybe make a list of the trees in the forest.
So far I've tried this, this is probably really painful to watch :D.
TestFilter that detects brightest parts of the forest(tree tops), then second brightest spots and third brightest etc..
Then I start clipping with buffered detected spots from dark part to the brightest parts and in the end of the clippin' I have really messy tree tops marked on raster..
And this doesn't really solve the original problem at all of making a shapefile for an each tree of the forest :D
So I figured that better approach might be something like this.
Spot the brightest tree tops --> Mark the tree top -->
Then start filling neighbour(s) of that spot with X color/value (IF neighbour < X) -->
Until all neighbour(s) of filled area are > X --> And this will be the border of tree on a shapefile.
Then repeat with the second brightest tree tops and leave the filled area alone. Etc.
So my questions is. Is there a way to use NeighbourFinder and/or other transformers to achieve that?
nightmarenightmare2
Best answer by JennaKAtSafe
Hi @tomppeli​ , The RasterConvolver might be what you're looking for. Here is an article that shows how this transformer works https://community.safe.com/s/article/neighborhood-functions
JennaKAtSafe
Forum|alt.badge.img+8
  • July 6, 2022
  • July 12, 2022
Thank you for the answer, that was the right way to go 🙂
