Hi there,
We have an excel file with an easy table. Just 2 columns: Position and Id. The file has about 100 lines.
We want to read the file and process each line. We have tried with a custom transformer but we are not able to process the lines individually. If we read the Excelfile we get the 100 lines and all lines will be process at the same time. If we convert the lines into a List, we get the error "Transformer/Factory test_loop_2_ListBuilder is blocking and cannot be used in a loop, but was found between 'Loop to test_loop_2_Looper1697190238 Input Splitter' and 'test_loop_2_Looper1697190238 Input Splitter'".
Has anyone an idea to make it?
I have found this link (https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/transformers_custom_looping.htm) but it helps me only with the loop. Not how I can process the ids separatelly.
Many thanks in advance!
