How to use SharePoint Online Connector to download files on SharePoint to a local drive?
  • August 10, 2023
  • 5 replies
  • 1471 views
As the question title states, I would like to use the SharePoint Online Connector to download files from SharePoint to my local computer's drive. I was able to set up the connector using a web service and it says "translation successful" when I run the SharePoint Online Connector on it's own but I'm not sure what readers and/or writers to add, or is there something wrong in the parameters? The files on SharePoint vary from .docx, .xlsx, and .pdf formats
If someone has a basic template to show that would be great. Thanks!
ctredinnick
Forum|alt.badge.img+20
  • August 11, 2023
The Sharepoint connector, assuming you have it set to Download as File should simply create a copy of the file from sharepoint in the local folder location you specify. It just does the download action, it doesn't matter what the file type is.
First question is has the file downloaded? My experience with Sharepoint is that 90% of time is spent authenticating getting access, and finding the correct location of the item/file to read/download. You say it ran without an error, so I assume it has? If it has, then the output port of the Sharepoint connector has a _download_path attribute added, which you can use if you want to take action depending on the file which has downloaded. FilenamePartExtractor -> Tester -> FeatureReader
  • August 14, 2023
When I run the SharePointOnlineConnector, I do get a "_download_path" in the output but when I go to check the folder on my local drive, no files/folders are being saved to it. I though I only needed the sharepoint connector to download files? I'm not looking to do any data manipulation on those files.
angwan
Forum|alt.badge.img+7
  • August 18, 2023
@nkachanyuk, if you are able to see sharepoint site, documents library and path, you'll get to see destination. Under destination, are you able to see three options(Attribute,File, Folder)?Here you've to choose file option and provide the path to download to . Also, choose an option to either reject or overwrite if file exist.imageimage
anthrax_79
Forum|alt.badge.img+4
  • November 30, 2025
Any update on this? I was able to get all the permissions and whatnot. I just need to download the file in each subfolders. I can see the files
And this is what my workspace looks like but nothing seems to be happening
The destination folder remains empty. I’ve tried all output ports
anthrax_79
  • November 30, 2025
Neverminsd. I got it. Note to self : Get a cup of coffee first thing in the morning 😁I had the wrong settings. should be download instead of List
