Does FME server or desktop use JAVA to perform any functions? If so, what JAVA is used? Oracle Java or Open Java?
  • October 5, 2022
  • 387 views
cruzh
Forum|alt.badge.img+3
We have been asked to audit all of our systems to confirm whether JAVA is being used. We want to confirm that we are compliant in licensing regarding anything Java. Thanks!
Best answer by david_r
The very short version:
Regarding licensing, note that both FME Server and Desktop are based on OpenJDK, which does not require a license.
  • October 6, 2022
cruzh
  • October 6, 2022
This is exactly what we needed. Thank you!
