How to download a zip file from an API using HTTPCaller
  • May 19, 2022
  • 173 views
a_ericsson
Forum|alt.badge.img+3
Hi! I'm trying to download a .zip-file using HTTPCaller. The zip-file is accessed via API by an order number generated when I placed the order for the data.
The response body looks like this: [{"href":"https://download-geotorget.lantmateriet.se/download/99d120aa-9532-43a9-a5a7-6128b333bc88/files/root/anlaggningsomrade_kn0125.zip?q=_9yzl22V_4v728pM........"}] (shortened down, was way to long to post here).
The 'anlaggningsomrade_kn0125.zip' is what I'm after. Is this possible? Any help is much appreciated 🙂
Best answer by redgeographics
First you use a HTTPCaller to make that API call that gives you the URL of the zip file. Then a second HTTPCaller to retrieve the file and save it.
Depending on what you want to do with it, you can also plug the URL directly in a FeatureReader and have FME process the data that's in the zip file.
Forum|alt.badge.img+62
  • May 19, 2022
a_ericsson
  • May 19, 2022
Great, thanks!
