FME Desktop (2022.1.0.0 (20220704 - Build 22618 - WIN64) hangs after changing anything in AttributeManager
  • September 21, 2022
  • 5 replies
  • 73 views
mathew.cooper
Participant
Forum|alt.badge.img+4
My workspace isn't complex yet if I make a small change inside and AttributeManager, FME Desktop hangs for a good minute. The CPU does spike while it hangs.
Has anyone else run into this issue before? This is a clean install on a beast of a machine so I shouldn't think its resource related.
Best answer by danminneyatsaf
Hi all, the issue has been resolved as of FME 2022.2 (b22743) and is now available in the FME 2022.2 beta which you can download here: https://www.safe.com/support/downloads/#beta
The fix will also be in the official release of FME 2022.2 coming soon!
mathew.cooper
Participant
  • Participant
  • September 22, 2022
UPDATE
This seems to have something to do with re-ordering attributes.
I have around 30 attributes which I've reordered in the AttributeManager so that the columns of the output are in order.
Once I do this, working with the AttributeManager is very slow.
@mathew.cooper​ can you attach your workspace or send it to me (mark at safe dot com). I think this issue has been fixed but I'd like to test that first before suggesting an upgrade for you.
mathew.cooper
Participant
  • Participant
Hi @Mark Stoakes​, thanks for the reply. I've just finished a remote session with Kailin (awesome experience btw). I sent the fwmt through and a case has been created (C682579). I'll upload a fresh template with feature caching and also a video of what I'm experiencing.
danminneyatsaf
Forum|alt.badge.img+13
For anyone else running into this issue - this occurs when opening, editing, and closing the AttributeManager while also having the Parameter Editor Window open. This typically occurs for workspace that contains a large amount of attributes. The workspaces we were able to reproduce the issue in contained ~250 attributes.
The workaround is to simply close the Parameter Editor Window if you have it open. This will resolve the workbench from freezing. I have submitted a ticket (FMEDESKTOP-13258) to get this issue resolved and we will notify users here once a fix is released.
danminneyatsaf
  • October 11, 2022
