community.safe.com
  • February 23, 2022
  • 0 replies
  • 12 views
Good Evening,
Firstly, I'm not sure if this is the correct place to ask this, or if there is a private message function that I haven't found. But I am looking to use FME to automate stream delineation via LiDAR derived raster analysis. I noticed your comment under this forum post (https://community.safe.com/s/question/0D54Q000080haNDSAY/generates-drainage-networks?t=1645628766878). I have downloaded your workflow and taken a look at some of the processes and was wondering if FME has had any updates to further the scope of my goal. Or if you have came across any new/better processes yourself since posting your suggestion. Once again, if this is not the proper place to leave this comment, I apologize. Please reach out at your earliest convenience.
