MSSQL Reader - How to detect underlying DB table schema changes?
boneill81
Hi Guys,
New to FME but really enjoying the journey to date. Today I hit my first confusing issue which although I have resolved I am pretty sure they must be a better way.
I had:
  • Created an MSSQL table
  • Created an FME reader which detected the schema including attribute types and so forth.
  • Did some processing and wrote to a file geodatabase.
But:
  • I then made some minor changes to the underlying MSSQL table i.e. changed text to decimal etc.
  • However the reader would not detect these changes. I had to delete and recreate the reader for then changed to be detected.
Is there some easier method which I am missing to get the reader to detect changes to the table schema in the database?
Apologies in advance if the solution is simple but I am missing it!
Thanks,
Barry.
Best answer by david_r
You can use the Update reader feature types functionality:
https://desktopmanualbasic.safe.com/DesktopBasic4Components/4.09.UpdatingReaderFeatureTypes.html
It does not automatically detect changes to the underlying tables, but it's easier than recreating the reader.
  • January 26, 2022
boneill81
  • January 26, 2022
Super David, many thanks for the help, it is very much appreciated!
