LineCombiner with attribute not working
  • January 11, 2023
  • 137 views
gvatin06
I have troubles in using the LineCombiner, with 2 different datasources as input. The first is fme_line from Postgis (MultiLineString, but deaggregated) and the second is fme_line from Shapefile. Both have the same projection system, are in 2D, and have the same attribute schema: only "troncon_id" as string which should be used as merging attribute. I would like to join common line between the two datasources and produce a unique dataset.
Hower, the resulting data a correctly merged when coming from the same datasource, but not merged for lines with the same troncon_id and common point (Qgis snapping option). They do not overlap or intersect.
Here are the parameters used:
LineCombiner parametersAn example of not combined lines :
Lines not combined
Best answer by dustin
Try using a Snapper with a small tolerance prior to the LineCombiner.
dustin
Forum|alt.badge.img+31
  • January 11, 2023
gvatin06
  • January 12, 2023
Thanks, ineed it works well! But now I have a problem with the TopologyBuilder located just after... I'll open another question for that.
gvatin06
  • January 12, 2023
