FME Server custom transformer was created with a newer version of FME Workbench Error
  • January 15, 2022
  • 81 views
I am getting the following error from FME Server: The custom transformer
'DateTime_Standard' referenced by this workspace was found, but could not be loaded. The custom transformer was created with a newer version of FME
Workbench
I have a workbench uploaded to FME server which contains 3 custom transformers. Each custom transformer presents the same error when I run the workbench. Both the workbench and the 3 custom transformers are in the same repository when the workbench is ran.
The FME desktop version for both the workbench and all 3 custom transformers is:
FME(R) 2021.1.2.0 (20210903 - Build 21627 - WIN64)
The FME server build is: FME Server 2021.1.1 Build 21619 - win64
I assume to fix the error, I need to match FME desktops build to FME server so I
have attempted to source FME desktop Build 21619. However that is not available on the safe software download page: https://www.safe.com/support/downloads/#past-versions
I would prefer to avoid upgrading FME Server at this stage but upgrading is an option.
As FME Server and FME desktop build numbers are slightly off, is that why this
error presents? If so, how can I match FME Desktop to FME Server builds? Am I
missing something fundamental with how I have my FME environment aligned?
Many thanks for any insight from the brains trust.
Paul
danminneyatsaf
Forum|alt.badge.img+13
Hi @paulbackhouse80​ sorry to hear you're running into these issues with customer transformers. Here's the download link for Build 21619 of FME Desktop: https://downloads.safe.com/fme/2021/fme-desktop-2021.1.1-b21619-win-x64.exe
Let me know if that fixes your issue!
