Search for a transformer to convert text from a dgn to points or cells
  • July 14, 2022
  • 16 views
aharport
Forum|alt.badge.img+4
Which transformer can I use to convert text from a dgn to points or cells? The origin of the coordinates should be retained and the actual text should become the new cell name.
Example: Text: "House" --> cell name: "House"
Forum|alt.badge.img+49
A text object is already a point, so one thing you can try is fill the attribute igds_cell_name with the value of igds_text_string using an AttributeManager. Your cell library should have those matching cells of course.
