Start an FME Workspace from a batch file which includes the paths to source and output files for inputs and outputs
  • November 11, 2022
  • 99 views
tigercole
I would like to start an FME workspace that has 2 CSV readers with a batch script that specifies the path for the CSV files that each CSV reader (in red). The workspace also has a CSV and Shapefile writer (in green) that I need to specify the output paths for.
FME_WorkspaceIs this possible?
tC/.
Best answer by nielsgerrits
Yes you can. When you run workbench, the first lines of the log display how to do this:
    Command line to run this workspace:
        C:\apps\fme_2021_2_6\fme.exe C:\TMP\test\none2none.fmw
          --PARAMETER "$(FME_MF_DIR_USERTYPED)test.tbx"
          --FME_LAUNCH_VIEWER_APP "YES"
tomfriedl
Forum|alt.badge.img+13
  • November 11, 2022
The command to execute a batch file is in the first lines of the logfile.
nielsgerrits
Forum|alt.badge.img+64
  • November 11, 2022
