How can I organize line paths in the order of their mileage markers?
  • June 22, 2021
  • 25 views
I am working with highway paths with point values and path lenths in kilometers.
@dinolobianco​ Can you use the MeasureExtractor to extract the first and last measures on your line and then sort by those?
Hello Markatsafe,
Okay, thank-you! I have troube setting the parameters correctly. I will try it and get back to you.
