How to convert a fme_collection(solid) to polygon?
  • September 16, 2021
  • 601 views
mahbouberezaiee
Hi.
I have some aggregated solids. In 2D view, they are like the attached image. I want to exactly convert them to polygon, keeping the inner lines (not a footprint). Do you know how can I do that?
virtualcitymatt
Forum|alt.badge.img+47
Hmm, Have you tried deaggregating, using a surfacefootprintreplacer and the Re Aggregating? Would this give you the result you want?
Another option is to use a 2DForcer, but the result would probably need a bit of cleaning up to remove possible duplicate segments
mahbouberezaiee
Hi @virtualcitymatt​  and thank you for your suggestions, but in both I will get a surface at the end. How can I convert a surface to polygon? I tried by many transformers but it was unsuccessful. Actually, I want to differentiate between polygons(roofs) that are constructed from some parts and those which are just one simple polygon. If you have any idea .
virtualcitymatt
To get the roof surfaces out of a solid this is one approach:
First use a GeomeryPartExtractor to extract the faces (this part, geometry type = IFMEFace). This should give you individual faces. You can then feed the faces through a PlanarityFilter which can extract the surface normals. Use a test filter to test for postive z (roof) negative z (ground) z = 0 (wall).
If you want polygons you can use a GeometryCoercer to force the faces to polygons.
You can then use a Matcher (match in the building ID) to get building which are made up of multiple faces, those which have no match will be just single polygons​
