How to merge a list of attributes based on just the attribute name
  • February 22, 2023
  • 230 views
ares
Forum|alt.badge.img+4
I would like to combine 2 datasets: one containing about 500 monument_id's and one with about 20 types with scores and remark fields that should be added to this monument_ids (to create a list of about 10.000 items).
As there is no attribute value to match (so FeatureJoiner or ReatureMerger doesn't work); can these somehow be combined based on predefined matching attribute names? Or what would be a good idea in this case?
Thanks in advance!
Best answer by ebygomm
If I've understood correctly, create a new attribute with a fixed value and use that as your join field in the FeatureJoiner with Join Mode set to Full
Forum|alt.badge.img+46
  • February 22, 2023
ares
  • February 22, 2023
Thank you. With this and changing the 'attribute conflict resolution' to 'prefer right' (in the FeatureJoiner; the dataset with the scores) this did the trick.
