Geodatabase to DXF attributes
  • February 12, 2021
  • 104 views
Greetings,
I created a very simple Workbench, that reads a ESRI File gdb and exports to AutoCad DXF.
I have selected the Attribute Output as Extended Entity Data.
The table column is present, but no attributes are showing up in the DXF file.
Any suggestions would be appreciated.
Thanks,
Clive
  • February 14, 2021
I ran the data through a data validator, found no geometry or error messages.
Some of the Dxf files have attributes. Any files that were 78Kb had no geometry or attributes.
All files that were bigger than 78Kb had attributes and geometry.
Any suggestions what Transformer, would assist to resolve the issue with files (78Kb)??
Regards,
Clive
  • February 17, 2021
Regards,
Clive
The FME exports the ESRI File Gdb Features into DXF files.
FME-workbench_LI (2)
Some of the files have Attributes + Geometry missing. Others have Attributes + Geometry??
FME-Output
Any suggestions?
  • February 17, 2021
FME-Output
Any suggestions?
There should be 201 polygons, FME outputs 218 polygons.
Some of the polygons cut across neighbours??
FME-Output
DanAtSafe
Forum|alt.badge.img+22
  • February 20, 2021
FME-Output
Any suggestions?
Hi @Clive Swan​ Your screenshot of your workspace shows 218 features getting written out to DXF. How do you know there should only be 201?
