how can import ADE in a CityGML LOD3 model
  • April 7, 2022
  • 31 views
keziaatsafe
Forum|alt.badge.img+8
  • April 13, 2022
Hi @estudy000​ ,
Are you writing to OGC CityGML? To load your ADE Schema file(s), you will need to open Parameters and for the Application Domain Extension parameter select Other from the drop down menu. This will allow you to upload or add your ADE Schema File(s).
CityGML
Hope this helps!
