Replacing attributes withing LAS file
  • March 17, 2022
  • 9 views
Guys,
Simple for u, not so simple for me...
I have a LAS with number of additional attributes. How can swap one of them as for example classification attribute or other standard LAS 1.4 format attributes
Thank you!!
hkingsbury
Forum|alt.badge.img+67
  • March 17, 2022
I'm assuming you're meaning components. One pointcloud feature can have many points all with different values for a component. That one pointcloud can also have an attribute which is not held against each individual point, only against the feature.
Have a look at the PointCloundComponent.... transformersimage
One thing to note though, is that its very likely other tools (outside of FME) will not view these new components:
https://community.safe.com/s/question/0D74Q000008tLyiSAE/detail
  • June 3, 2022
I never got a chance to say thank you...
Finally got there, with your help...
Thanks once again for all your time,
j
