Hi, I am newish to FME professional and I am wondering if there is a way of extracting the filename of a hyperlink (in google sheets).
  • January 24, 2021
  • 23 views
liboc
Forum|alt.badge.img+9
To put this into context I have a google sheet which has hyperlinks to photos. It shows the shared link but not the filename. I need to be able to extract the filename (and ideally the directory path from Google drive) so I can relink the photo to the new location. Hope this makes sense
Best answer by caracadrian
To get the Filename and Relative Path you have to use the GoogleDriveConnector set to List.
As far as I know there is no way of reconstructing them from the share_link directly.
caracadrian
Forum|alt.badge.img+23
  • January 24, 2021
liboc
  • January 25, 2021
Thanks @caracadrian​ that worked perfectly and it also extracts the relative_path which is exactly what I needed. Now I just need to create the new hyperlinks in the excel sheet using the data extracted. Thanks again 😀
