I have a column of multiple lat/long points and trying to convert them to a line.
The thing is some of the coordinates only have 2 points and some have 30+ to make up the lines. I can use AttributeSplitter and create lists, but they are inconsistent when I try to pull out the list using AttributeCreator as some only have 2 and some have 30+. I can split it using ",0;" and then split it again into a separate lat/long for each point. It seems like there has to be an easier way.
How would should I go about extracting all of these lat/longs into a line? LineBuilder isn't working for me.
Capture
Thanks!
Best answer by ebygomm
So one possible way
Use an attribute splitter splitting at the ; to get a list of coordinates, explode this list so you have a feature per coordinate, a second attribute splitter splitting at , to split x,y and z coordinates. Use a vertex creator to create the points from these list items, then a line builder to join into lines
Capture
Forum|alt.badge.img+35
  • March 15, 2021
Can you post an example?
  • March 15, 2021
Just took a screenshot of the column.
  • March 15, 2021
So one possible way
Capture
  • March 15, 2021
ebygomm wrote:
So one possible way
Capture
Do I use AttributeExploder after AttributeSplitter? Splitter, Exploder, Splitter, VertexCreator? Won't this only give you two coordinates for each line?
  • March 15, 2021
Awesome! Thank you so much!
mark2atsafe
Forum|alt.badge.img+44
  • March 15, 2021
The AttributeSplitter (splitting on ";") will create an FME List of coordinates. Like:
  • Feature 1:
    • List Item 1: x,y
    • List Item 2: x,y
    • List Item 3: x,y
  • Feature 2:
    • List Item 1: x,y
    • List Item 2: x,y
  • Feature 3:
    • List Item 1: x,y
    • etc
Then the ListExploder (not AttributeExploder) will give you a feature per coordinate pair.
  • Feature 1: x,y
  • Feature 2: x,y
  • Feature 3: x,y
  • Feature 4: x,y
  • Feature 5: x,y
  • Feature 6: x,y
  • etc
The next AttributeSplitter extracts the x from the y and the VertexCreator now converts those to point features.
The LineBuilder at the end joins the points together where they belong to the same original feature.
So, yes, AttributeSplitter, ListExploder, AttributeSplitter, VertexCreator, LineBuilder.
mark2atsafe
  • March 15, 2021
Another solution would be to encode the coordinates inside a standard micro-format that FME can convert with the GeometryReplacer.
For example, with your data as:
5,5;12,5;15,7
Use a StringConcatenator to add
LINESTRING(
to the front of the coordinate list and add
to the end.
Now use a StringReplacer to replace , with a <space> character and ; with , which will give:
LINESTRING (5 5,12 5,15 7)
FME can now create the geometry automatically from that string with the GeometryReplacer transformer, where Geometry Encoding = WKT Well Known Text
  • March 15, 2021
5,5;12,5;15,7
LINESTRING(
to the end.
I think they're y,x,z which complicates matters​
mark2atsafe
  • March 15, 2021
It certainly would!
virtualcitymatt
Sounds like a Safe Software interview question 😏
