Divide all numbers in an attribute (scale geometry)
  • July 11, 2019
  • 36 views
p.jeremie
I have an attribute WKT_coordinates that I use to create a geometry with WKT format.
My problem is all the numbers in this attribute are too big by 100.
I am looking for a simple way to divide them all by 100.
Example of string in WKT_coordinates :
((86530120 638698160,86530140 638700660,86526150 638712680,86512380 638737780,86510880 638737790,86507360 638734820,86530120 638698160))
I would like to have
((865301.20 6386981.60,865301.40 6387006.60,865261.50 6387126.80,865123.80 6387377.80,865108.80 6387377.90,865073.60 6387348.20,865301.20 6386981.60))
I can have geometries with multiple parts too :
((100 100,200 100,200 200,100 200,100 100),(125 125,175 125,175 175,125 175,125 125))
and want :
((1.00 1.00,2.00 1.00,2.00 2.00,1.00 2.00,1.00 1.00),(1.25 1.25,1.75 1.25,1.75 1.75,1.25 1.75,1.25 1.25))
Any idea ?
Best answer by ebygomm
Would creating the geometry, using the scaler, then reextract the wkt work for you here?
Forum|alt.badge.img+46
  • July 11, 2019
p.jeremie
  • July 11, 2019
@egomm yes perfect, I didn't know about the scaler but it fits my needs perfectly. I just create the geom and then scale it.
My goal is not to have the WKT but a correct geometry so it's ok like that.
Thank you !
