Clip LAS with Shapefile
  • March 17, 2021
  • 251 views
I'm working with relatively large LAS files and only needing small portions at a time. Is it possible to use a Shapefile to "trim" the excess points before transformation?
Best answer by redgeographics
Yes, that should be possible. Either through a Clipper or by using a feature from the Shapefile as the initiator for a FeatureReader.
Forum|alt.badge.img+62
  • March 17, 2021
virtualcitymatt
Forum|alt.badge.img+47
Yeah, using a the shapefile as the filter in a FeatureReader is a good option here.
