I'm having trouble trying to push the contents of a CSV file stored in an AzureBlobStorage environment into a SQL DB Table.
  • August 12, 2021
  • 23 views
FME_Azure1I'm having trouble trying to push the contents of a CSV file stored in an AzureBlobStorage enviornment into a SQL DB Table. I can download the CSV file directly using the AzureBlobStorageConnector, but I'd like to be able to d it all without creating the temporary file that would normally result. I'm trying to download as an attribute which seems to work, but I can't get the data out of the resulting list as it ends up with a single column from listExploder with all the contents and the index for each element from the file in their own rows.
e.g.
_list _element_index
col1_name 0
col2_name 1
col3_name 2
col1_value1 3
col2_value1 4
col3_value1 5
col1_value2 6
col2_value2 7
col3_value2 8
Note in the image, there are 161,631 records output by the ListExploder, from a file with 11,545 rows (including header) of data and 14 columns of attributes in the CSV.
nielsgerrits
Forum|alt.badge.img+64
What I did in this case:
  • TempPathnameCreator to create temporary DownloadFolder.
  • Download file to folder @Value(DownloadFolder).
  • FeatureReader to read file in @Value(DownloadFolder). I know you can't select the attribute but just entering @Value(DownloadFolder) in the field works fine.
  • etc.
