Use FME Desktop to produce CIM XML
  • January 13, 2021
  • 146 views
Hello Everyone,
I am trying to produce a CIM XML document with FME Desktop. I found an example template here:
https://community.esri.com/t5/electric-documents/sample-common-information-model-cim-xml-data-translation/ta-p/913831
The template is complex and I can't find any documentation on it other than some comments in the workspace. Are there any other documents related to the template, or a good resource for learning how to use FME for CIM XML?
Thank you.
