LineCombiner - How to ignore orientation of the input lines
  • May 12, 2021
  • 5 replies
  • 94 views
ireen
Forum|alt.badge.img+5
I would like to combine lines into 1 line/route based on an attribute. The LineCombiner seems not to combine lines with a different orientation. So, if two lines have the same starting point, they are not combined. I put the parameter "preserve orientation" on "no", but this doesn't seem to have any result. The result has too many lines (different line at almost each beginning or endpoint of the incoming lines, due to a different orientation). Any suggestions?
LineCombiner
nielsgerrits
Forum|alt.badge.img+64
I can't reproduce your issue and I did not expect I could. I suspect the startpoints are not exactly the same. You can try to fix this with a Snapper transformer upstream the LineCombiner.
connecter
Forum|alt.badge.img+10
  • May 12, 2021
Or try the Input Feature Topology to vertex noded.
ireen
  • May 12, 2021
I tested both. Setting the Input Feature Topology to vertex noded results in even many more separate lines in the result. The snapper reduces it a little bit, but I still got 120 resulting features, instead of the expected 22. Snapper_LineCombiner
nielsgerrits
I think you first need to find out what the issue is before we can help you to fix it. If you want more help I think you need to share (a sample of) your data.
ireen
  • May 12, 2021
I think I found a clue ... The LineJoiner keeps splitting lines where multiple lines (with different attributes) overlap. So if route F1 and F3 parlly have the same location, the resulting F1-line is split at the point where F1 and F3 get a different route.
