Custom NAD83 CSRS epoch 2010 projection system definition throws an error
  • January 11, 2022
  • 96 views
Hello community,
I need to output data in MTM or UTM systems for Canada but in NAD83 CSRS epoch 10.
I know the EPSG code does not exist for such projected coordinate system.
I used the ESRI WKT to create a custom definition for FME using this tool: https://demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Start.fmw?
And then i saved and used the coordinate system definition i got and added a datum definition:
Here they are:
DATUM_DEF NAD83CSRS2010               \\
  DESC_NM  "North American Datum of 1983 (CSRS) version 6"        \\
  SOURCE   "Metashape"           \\
  ELLIPSOID GRS1980
COORDINATE_SYSTEM_DEF MTMZone7-NAD83CSRS(2010) \\
  DESC_NM "MTM7 NAD83 CSRS 2010" \\
  GROUP MTM \\
DT_NAME NAD83CSRS2010
  ORG_LAT 0 \\
  PARM1 -70.5 \\
  PROJ TM \\
  QUAD 1 \\
  SCL_RED 0.9999 \\
  UNIT METER \\
  X_OFF 304800 \\
  Y_OFF 0
When i use this in the workbench i get the following error:
is not a supported projection
Unable to initialize coordinate system structure for coordinate system `MTMZone7-NAD83CSRS(2010)'
Reprojector: Could not create reprojection engine
What am i missing? Are there example of creating a projected coordinate system for NAD83 CSRS epoch 2010?
Kind regards
daveatsafe
Forum|alt.badge.img+20
  • January 13, 2022
Hi @edoh-alove​,
Your definition is missing the '\\' continuation character at the end of the DT_NAME line, cutting off the rest of the definition. However, once this is fixed, you will also need to define a transformation between NAD83 and NAD83CSRS2010 for the reprojection to succeed. CSRS transformations usually use a grid file supplied by the applicable province.
You may have better luck with the PROJReprojector, which has a much larger library of coordinate systems and transformations, and can automatically access tranformation grids online.
  • January 14, 2022
Hello @daveatsafe​
Awesome. Thanks very much.
I have the transformation grid (CSRS 2010 - NAD83) for Quebec but the format is not recognized by FME. It's .csc format. How can I convert to .gsb? I can share via email (because it's from one of our customers).
I was working in FME Desktop 2019.1 and FME Server 2019.1.
It doesn't offer PROJReprojector transformer. However i tested it in Desktop 2021.1 but when i use Automatic transformation, it does'nt seem to collect the grid online to reproject.
I think i do need to add the grids anyway for Canadian CSRS transformation?
Thanks a lot for the help
daveatsafe
  • January 14, 2022
Hello @daveatsafe​
Hi @edoh-alove​,
Please email the grid file to me (dave.campanas@safe.com) and I will find out how we can use it in FME.
