FME/Arcmap licensing error
  • December 19, 2022
  • 6 replies
  • 39 views
fme_can_do_it
Forum|alt.badge.img+12
When I try to run a workspace on the FME server, I receive this error. On my machine, I have ArcMap and Pro installed with 64-bit background geoprocessing. I am also reading data from File Geodb using the Esri Geodatabase (File Geodb) reader
ArcGIS Enterprise 10.9.1 has been upgraded to ArcGIS Enterprise 11.0, and I am running FME Desktop 2022.0.1.0 and FME Server 2022.0.0.2.
It is unclear why I am getting this error. Is it because we have upgraded ArcGIS Enterprise and are using FME Desktop 2022.0.1.0?
Thank you,
Best answer by hkingsbury
Have a look here: https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
For ArcGIS 11, you need 2022.1 or newer to work with it
hkingsbury
Forum|alt.badge.img+67
  • December 19, 2022
I had a similar issue with ArcGIS pro 3.0.x and the final solution was to upgrade FME Desktop to 2022.2 (2022.1 did not really work, I was not able to connect new readers/writers to my enterprise geodatabases)
fme_can_do_it
  • January 4, 2023
@hkingsbury​ Both the FME server and desktop have been updated to the latest version 2022.2.1. However, I still receive this error when I run the workspace on the FME server. The FME desktop runs workspaces without error. In the workspace, ESRI ArcGIS Compatibility is set to ArcGIS Pro.
  • January 18, 2023
@fme_can_do_it​ my understanding is that you need FME Server installed on a server that has ArcGIS Server on it. Desktop/Pro on Server no longer works. At least that is what I was told by FME support.
bill3648
  • April 3, 2023
Good luck it's buggy
bill3648
  • April 4, 2023
Uninstall ArcPro, just leave enterprise it will work.
