I am reading data from a file geodatabase in my workspace. The data is huge and takes time to process data. I have set up a query to only filter data that ends with .2022 but the workspaces are still slow.
Therefore, I intend to set up a query on a Date Modified column and a Create date column in the file geodatabase. This will filter only data modified and created within the last seven days. I can't figure out how to set up a query and filter data from the last seven days in FME.
Any help and advice would be greatly appreciated.
Thank you,
