How to write into txt file with a max of 250 lines, 100 files, and while keeping lines with same id in same file
  • July 22, 2021
  • 7 replies
  • 228 views
Forum|alt.badge.img+5
I have a huge dataset to write in text files.
Each line has a file_id and an identifier. This identifier is not unique and can be repeated.
I must write everything in a maximum of 100 files.
I must write a maximum of 250 lines per file.
To do that, since each file must have an id, I thought I could simply use the file_id in the file name when writing.
Here is what I did :
  • I use a Counter to add a _count attribute to each line.
  • I divide this _count attribute by 250 to create the file_id attribute.
  • I use AttributeRounder to round the file_id.
  • I write the text files with a FeatureWriter and by setting the name : "file_@Value(file_id)".
Once I've done this, I can write a maximum of 250 lines in each text file.
However, all lines with the same identifier must be in the same file, and with just the steps above, that's not the case.
So I thought about :
  • using Agregator to group by the identifier and create a list of file_id.
  • using ListRangeExtractor to extract the maximum file_id in the list.
  • using AttributeManager to set file_id with the maximum.
I thought I was done with this, but then I realised that, since the file_id was already computed, I was just adding more lines at the beginning of the next text file. So I will have more than 250 lines...
What should I do since I can't use loops in FME ? Is there a more simple way to do things ?
Here is an image to help you understand, in case my explanations are not clear :points
gazza
  • July 22, 2021
Can you you sort by Identifier and also File_id, with File_id in descending order. Then you just need to look for when identifier has changed from the previous record, using the Adjacent Features capability of the AttributeManager and increment a file name counter when it changes.
jdh
Forum|alt.badge.img+40
  • July 22, 2021
Are there more than 100 unique identifiers? Is it possible to have more than 250 records with the same identifier?
If the answer to both is no, you could fanout on the identifier
SM.txt: a,b,c
TER.txt: def
If you need the filename to be an incrementing number, then sort your data by identifier, and then use adjacent feature handling to create a file id that increments every time the identifier changes value.
incrementOnChange
If your 100 file constraint means that you need more than one type of identifier in the same file, than things become more complicated. It essentially becomes a bin packing problem where your bins have a capacity of 250 and each unique identifier is an item with a weight equal to the number of features of that identifier.
  • July 23, 2021
SM.txt: a,b,c
TER.txt: def
incrementOnChange
I'm not sure about the number of occurences, but I doubt there would be more than 10 data lines with the same identifier. Still, I cannot fannout the identifier, since I should have several different identifiers in one file. It's only when approaching the 250 lines that I must be carefull, that data with the same identifier are not separated in different files.
  • July 23, 2021
SM.txt: a,b,c
TER.txt: def
incrementOnChange
Indeed, I have started using a "weight" attribute that contains the number of occurences of each identifier, but so far, none of my processes work...
  • July 23, 2021
Thank you for the Adjacent Feature, I did not know that.
I tried your method, however, when changing the file id, I have the following problem : if nearing the 250th line of data, there are data lines with the same identifier, they are indeed moved from file N to file N+1 and stay together. However, in that case, file N+1 has more than 250 lines, since some lines were added at the beginning. I'm trying to manage this using some "weight" attribute : that attribute contains the number of occurences of an identifier, but so far, it dos not work...
geomancer
Forum|alt.badge.img+60
  • July 23, 2021
This can be done with a recursive SQL command (see example below), using the InlineQuerier.
In the attached workspace I use a simple data set, containing a row number as identifier (RowNumber, starting with 1) and a number of items (NumItems). Also the workspace contains a Private Parameter defining the maximum number of items in a bin $(MaxItemsInBin), set to 100.
The idea for the SQL command (for SQLServer) I found here; I simply rewrote it for my dataset in SQLite.
with recursive
    C ("cRowNumber", "cNumItems", "cCustomSum")
as ( --Get first record
    select "RowNumber", "NumItems", "NumItems"
    from "Data"
    where "Data"."RowNumber" = 1
    union all
    --You add the new value of NumItems to the sum of the previous record
    --If the running sum remains less than the maximum capacity of the bin or it reaches exactly the maximum capacity of the bin
    --   then there is nothing to do
    --If the running sum overtakes the maximum capacity of the bin, the new value will be part of a new bin and so
    --   the new value is added to the multiple of $(MaxItemsInBin) that has been overtaken
    select
        "RowNumber",
        "NumItems",
        case
            when (((C."cCustomSum" + "Data"."NumItems") / $(MaxItemsInBin) = C."cCustomSum" / $(MaxItemsInBin)) or ((C."cCustomSum" + "Data"."NumItems") % $(MaxItemsInBin) = 0))
                then (C."cCustomSum" + "Data"."NumItems")
            else ((C."cCustomSum" + "Data"."NumItems") / $(MaxItemsInBin) * $(MaxItemsInBin)) + "Data"."NumItems"
        end
    from "Data"
    inner join C on "Data"."RowNumber" = C."cRowNumber" + 1
select
    "cRowNumber", "cNumItems", "cCustomSum", ("cCustomSum" - 1) / $(MaxItemsInBin) as cBinNumber
from C
bin_packing_resultsSpecial thanks to @jdh​ for mentioning "bin packing", this triggered my search for a SQL based solution.
gazza
  • July 29, 2021
I'm thinking you need a running total of now many records are in the current file. Using the adjacent feature functionality you can look ahead at the next group size and decide if it will fit in the current file. If not the start a new file and reset the running total to zero. Using VariableSetter and VariableRetriever to keep the running total.
