Hi ! I have a workspace with the version 2018. I would like to launch with workspacerunner with an other workspace with the version 2022. That doesn't works but maybe there is a way to make it works. Do you have an idea? Thanks !
  • April 7, 2023
  • 16 views
alc33
Forum|alt.badge.img+14
dustin
Forum|alt.badge.img+31
  • April 7, 2023
You can't do this with a WorkspaceRunner, but you can call up FME2022 via command line using a SystemCaller.
https://community.safe.com/s/question/0D54Q000080hObZSAU/run-workbench-from-command-line
