Colored line with respect to Y values
  • August 3, 2020
  • 9 views
Hello!
Can comebody tell me what is the solution, for me to be able to color line with respect to Y axis values. I want to have something like in the attached image below:
Thank you in advance.ScreenShot1
Forum|alt.badge.img+62
If you create a grid (1 column, just as wide as your line) with the colors you want and then use that as Clipper features the color attribute will transfer over to the clipped lines.
Screenshot 2020-08-03 at 10.47.17
I'm using conditional values in the FeatureColorSetter to set the line color based on the _row attribute coming out of the 2DGridCreator.
