Auto cad attributes to write to create a dwg for a raster
  • July 13, 2021
  • 36 views
I am trying to automate a process that I currently accomplish using Autocad Map 3D, manually. That is to say create a dwg that referenced a raster and when added to Autocad will pull in the raster in the correct location. At the moment I insert a raster into Map 3D , zoom to extents and save as a dwg. This produces a dwg with the same name as the raster. I have not been able to find out what is in the dwg, so I don’t know how to do this in FME.
I am presuming there would be a reference to the raster, it’s extents, scale …
Does someone know what FME. Autocad attributes I would need to write ?
I am also assuming there would be no geometry in the dwg, but again I don’t know.
thanks for any assistance,
Ian
sigtill
Forum|alt.badge.img+25
  • August 4, 2021
You can READ a raster with FME, make sure its at the correct location and Coordinatesystem and then just add a DWG-writer. That should work. Creating a DWG-file and an attached *.png file withouth any other attributes needed. Works ok in my case. Do you have any example data?@ian2016​
