How can I transpose a column which was extracted from a json file?
  • January 19, 2021
  • 95 views
mda
Forum|alt.badge.img+7
I am extracting two attributes ( Naam, Value) from a json file. The contents of the "Naam"attribute are actually attributes names and the contents of the "Value"attrbute are the values. So what I need is to transpose the "Naam" attribute to columns and fill those columns with the content of the "Value"attribute (see attachments). I have tried attributepivoter and also attribute Transposer custom transformer. Unfortunatley, I keep getting nothing useful or empy output. Could you please help me with this!
muzhnasto
Forum|alt.badge.img+12
  • January 19, 2021
tomf
Forum|alt.badge.img+23
  • January 20, 2021
You need to follow the AttributeTransposer with an AttributeExposer in order to see the attributes in the table view of Visual Preview/Data Inspector
mda
  • January 20, 2021
Indeed the AttributeExposer is the key. Thanks a lot!
