Getting a permission error when using window task scheduler, but not when running FME desktop manually.
Hello,
Our
organization has a server specifically set up to run FME desktop workbenches. We
have made the GIS connections public and have made every effort to have the
same user that saved the workbench also be the user that is triggering the
windows task scheduler. There is an excel file that is located on another
server that FME can access when the workbench is run manually. However, when it
is run with window task scheduler there are two errors.
2021-07-30
12:01:24|  7.9| 0.0|ERROR |Excel Reader: Failed to open the
dataset '\\\\vmcognos\\GIS\\COT Inter Department Meters Consumption Accts-en-us.xlsx'. Error
message was 'Permission denied.'
2021-07-30
12:01:24|  7.9| 0.0|STATS |Stored 1007 feature(s) to FME feature
store file
`C:\\Users\\COTAGS~1\\AppData\\Local\\Temp\\CIS_GIS_Bridge_EDITSDE_GISFCTableCreation_PROD_120104\\inspector.ffs'
2021-07-30
12:01:24|  7.9| 0.0|INFORM|Saving spatial index into file
'C:\\Users\\COTAGS~1\\AppData\\Local\\Temp\\CIS_GIS_Bridge_EDITSDE_GISFCTableCreation_PROD_120104\\inspector.fsi'
2021-07-30
12:01:24|  7.9| 0.0|INFORM|Finished saving spatial index into
file 'C:\\Users\\COTAGS~1\\AppData\\Local\\Temp\\CIS_GIS_Bridge_EDITSDE_GISFCTableCreation_PROD_120104\\inspector.fsi'
2021-07-30
12:01:24|  7.9| 0.0|INFORM|Excel Reader: Closing dataset
'\\\\vmcognos\\GIS\\COT Inter Department Meters Consumption Accts-en-us.xlsx'...
2021-07-30
12:01:24|  7.9| 0.0|INFORM|Styles created: 21
2021-07-30
2021-07-30
12:01:24|  7.9| 0.0|ERROR |A fatal error has occurred. Check the
logfile above for details
2021-07-30
12:01:24|  7.9| 0.0|INFORM|Translation FAILED with 2 error(s)
and 2 warning(s) (0 feature(s) output)
I
have uploaded the complete log file in case this provides more information.
rahulsharma
Forum|alt.badge.img+10
Hi @lmawhinney7175​
If you are running FME Workbench via Task Scheduler, the user running the Task needs permission to access the UNC path. On General Tab --> Security Options --> Change User or Group
Ensure that the User Account has sufficient permission to access the network path see below.
TaskSchedular_RunAs
Thank you for suggesting we check the user account in task scheduler. As I understand it, this user has permission to the network path and is the same user for the FME workbench. Any other thoughts?
rahulsharma
hi @lmawhinney7175​
I was wondering if you were able to resolve the issue or still having the issue. We can definitely try to troubleshoot this via a support ticket.
Hey devs, i guess the solution could be checking the box saying "Run with highest previllages".
and also lookout for all other settings conditions and settings tab, some of the default values are not much friendly with common tasks. hope you'd have solved the prob already......... share what's it?
daraghatsafe
Hi @rockin-rockie​ are you experiencing this issue?
