Error when trying to read from Azure Blob Container
  • December 4, 2020
  • 12 replies
  • 625 views
when trying to use the select file from web - azure blob storage option on a reader. I can get to the container and i can select files that are at the top level in that container but if i want to go into a folder to select a file in the folder i get an error. ( see screenshots )
Any help appreciated
Hi @baznewman07​
I just tested this in FME with version 1.0.6 of the Azure Storage package and it lets me select it and read the data in fine.
Screen Shot 2020-12-04 at 7.58.28 PM
Can you try using the AzureBlobStorageConnector transformer to bring in the CSV? Or try embedding the credentials instead of using a web connection?
If you're not on the latest version of the package, I would also recommend downloading it and trying with that.
  • December 7, 2020
Hi @baznewman07​
very strange, i downloaded that version to test it and it still didn't work on mine.
  • December 7, 2020
I have just realised this is specific to a certain way of handling the data. If i write out a csv file to blob storage using azure databricks then it creates a couple of other files along with the csv. I think this is what is causing the error when i try and access those files inside of the folder. If i write simple csv files inside a folder structure then it works fine.
  • November 24, 2021
Hi @baznewman07​
I got the exact same error. Anything directly under the container can be read without any issues. Opening any folder under the container will result in the error ("It is not a valid operation to get a list of items in '%s' (ID '%s')", '<folder name', '<folder name>/').
imageAny progress so far @baznewman07​ ?
@jlutherthomas​ My Azure Storage package is 1.3.1 by default. Still not work.
  • November 24, 2021
Screenshot 2021-11-24 at 07.59.22@kevint​ I have been able to do this for a while now.
I am using
safe.azurestorage.AzureBlobStorageConnector Version 2
Azure Storage - safe.azurestorage [1.0.6]
  • November 25, 2021
Thanks @baznewman07​ .
I downgraded my safe.azurestorage to 1.0.6 but still got the same error. I think you got the same issue from your comment a year ago? For safe.azurestorage.AzureBlobStorageConnector, could you let me know how to check its version, please?
I managed to overcome this issue by tweaking the url that fetches the data. Hopes it will help someone else.
For example: assume I can read a csv called model.csv file directly under the container. Its url (in dataset parameter) will look like this:
fme://safe.azurestorage.microsoft-azure-blob-storage/model.csv?id=model.csv&module=....
To read another csv called test.csv under the test folder inside the same container, I just need to modify the the table name and the id parameter in the url to:
fme://safe.azurestorage.microsoft-azure-blob-storage/test.csv?id=test/test.csv&module=.....
  • November 25, 2021
@kevint​ right click on the transformer and click on 'show summary annotation'
I'm not sure if this was resolved for @kevint​ , but I tried the steps for show summary annotation and do not see the version for safe.azurestorage.AzureBlobStorageConnector
  • March 24, 2022
That is strange, as you can see i get the version when i do it.
Screenshot 2022-03-24 at 07.30.51
That is really weird - I'm running FME 2020.2 and am wondering if versions are only reported for newer builds (?)
  • March 24, 2022
Not sure, i am using
FME(R) 2021.2.3.0 (20220131 - Build 21812 - macosx)
@geographicus97​ You can enable transformer version in FME Options > Workbench:
Screen Shot 2022-08-03 at 2.03.22 PM
FME Option > Packages will also show you the package version.
