CSV Reader wrongly classified column
  • December 14, 2021
  • 6 replies
  • 98 views
I am loading in a large address data set in CSV format
The reader has wrongly classified my coordinate columns as "time". This causes the VertexCreater transform to add incorrect geoemtries
When I click "User Attributes" on the Reader I cannot change the column type from time. Everything is greyed out. How can I best override this
Screenshot 2021-12-14 at 11.25.21
nielsgerrits
Forum|alt.badge.img+64
This is a recently introduced functionality which turned out a bit too aggressive and is changed back in 2022 beta.
If you use a FeatureReader you can just hit "Parameters..." and choose Manual under "Attribute Definition" and change the Attribute Type.
FeatureReader ParametersCSV ParametersIf you use a Classic Reader, click "Readers" --> "Update Feature Types..." to get to this screen.
  • December 14, 2021
Thanks but I am struggling to understand why this can't be done as a normal reader?
nielsgerrits
I updated the answer, you can also change this with a Classic Reader. I just never work with classic readers / writers so I didn't knew from the top of my head.
  • December 14, 2021
This has not fixed my issue
Here is the output of a simple vertex creater after reading in the CSV file
For some reason the points have been grouped and gridded? They should show an even distribution over a polygon (this works correctly in QGIS). Is there something else I am missing about the CSV reader?
Thanks
VertexCreater
nielsgerrits
It is hard to say what went wrong without data & workspace. To what type did you set X_COR / Y_COR?
rahulsharma
Forum|alt.badge.img+10
  • December 14, 2021
Hi @davebarter​
You can do this in a normal reader, this option is not enabled by default.
Go to Tools --> FMEOptions --> Workbench --> Allow Reader Feature Type Editing
EnableReaderFeatureTypeEditingFor the second part of Vertex Creator, as @nielsgerrits​ mentioned if you can provide a small sample of the CSV file, we can investigate this further.
