Jp2 files sits on each other in the same extents
  • February 22, 2021
  • 35 views
canerakin
I have multiple (210) jp2 files, FME reads them but the extents seems the same for all of them. Therefore they sit top of each other. If I check the raster files in ArcGIS Pro, they are next to each other and extents are different.
The coordinate system is not in the list of FME. I created a custom one using the tool below.
https://demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Start.fmw?
The coordinate system is ESRI:102717.
https://epsg.io/102717
One warning that I am getting when I run the workbench is JPEG2000 reader: `<MYLOCALPATH>\\w_10890984_12_17100_4bd_2017.aux' exists but could not be opened. File contents may be invalid, or the file format may not be supported.
Best answer by andreaatsafe
Hi @canerakin​ ,
I took a look at your sample rasters files you shared.
The issue is the tab files associated with the JP2 files all have the same definition. They are both defining the same extent in the tab file, hence the files are stacking.
FME reads in JP2 files and uses the tab file to georeference if the tab file is available. Whereas in ArcGIS, a world file (jpw) or auxilery files are used for the georeferencing.
If you remove the tab files, then FME reads in these files in aligned next to each other.
Hope this helps,
Andrea
andreaatsafe
Forum|alt.badge.img+15
  • February 23, 2021
Hi @canerakin​ ,
Hope this helps,
Andrea
