how to straighten line
  • January 25, 2022
  • 6 replies
  • 124 views
is there an easy way to straighten a line.
i have created a shortest route on a grid, now i want to straighten this line as it is indicated in the picture. best with 90 degree angle
thanks in advance
Best answer by takashi
Hi @sebastiangoerck​ , I think you can use the NeighborFinder to find the vertex of your desired right angle corner. See the screenshot.straighten-line-example
dustin
Forum|alt.badge.img+31
  • January 25, 2022
In theory....
  • Extract the start and end points of the lines using the Snipper transformer.
  • Using the BoundingBoxExtractor, extract the bounding box of each input line, and then use the GeometryCoercer to convert to line.
  • Using the PointOnLineOverlayer, split the bounding box line with the points from the Snipper. This should give you 2 lines from the lines output port.
  • Using the Snipper, snip off each end of the lines
  • Feed the 2 lines into the Candidate port of a SpatialFilter. The Filter will be the original line. From the Passed port should be the 'straightened' line.
chrisatsafe
  • January 25, 2022
Extracting the start and end points of the feature is definitely the easiest approach. You can also accomplish this with the CoordinateExtractor, ListElementCounter and 3 VertexCreators to recreate the line with a 90 degree turn. The attached workspace might help with this if you haven't already solved it!imageExample 1 (highlighted is the new line):
imageExample 2 (highlighted is the new line):
thank you for your support.
Your "90DegreeLineCreator" seems to be a good approach, but unfortunatly i cant use it with FME 2020 (we have this version on our server, so i have to use this one) and if i try it with 2021, then the result is not what i expected. the angle is on the wrong side, the angle must be on the same side as the origin line angle is (see attachment, blue line on the right side)
  • January 26, 2022
chrisatsafe
  • January 26, 2022
It's possible the lines we are comparing were drawn in a different order. If you swap the coordinates in the second VertexCreator that should do the trick (essentially changing which x/y axis to align to). Try setting it to this instead:
@Takashi Iijima​ your solution works perfect...thank you
there are always several ways that lead to the result, for me this method is best
thank you all for your time and your support!
