Is there a bug in schedules when changing start times for "Occur Only Once"?
  • March 4, 2022
  • 7 views
agelfert
Forum|alt.badge.img+8
Hey, I love FME so no product bashing here.... but is there a bug in FME Server 2020.2?
I have a schedule that's set to "Occur Only Once" and that I enable to run on a certain/time when I need it. In the past, this has worked great. I'd move up the date to whatever needed, enable it and hit "Okay".
Since upgrading to 2020.2 last year, I've noticed that when I do this, the new date I select in the calendar will not take...
image... and when clicking 'Okay" in haste or out of habit, it will save schedule with the old date from the past and - now enabled - start running immediately. Bug, user error?
Plan to upgrade to 2022 when it comes out. So if I don't get any nibbles here, I'll see if that resolves it.
carmijo
Forum|alt.badge.img+11
  • September 30, 2022
Hi @agelfert​, it sounds like you're doing everything right. did you find a solution or end up moving to 2022?
