pointcloud to DSM based on Z
  • April 2, 2021
  • 178 views
koenvdw
Hi
I want to make a DSM from a pointcloud.
I have used the rasterDEMgenerator and the imagerasterize.
They both work and I get a good result, but only visual. When I load the DSM in Qgis and start to sample it, I get the color codes or something instead of the height.
I can't seem to find a way to change that.
This is how I I would like it:
1This is the result I get with:
1a
This is how I would like it:
2
this is my result:
2a
This is my workbench:3I did change the rasterinterpretationcoercer to gray8, so now I also get one band, but it's still not the height.
The imagerasterizer has only color or intensity as input component...
I think the rasterdemgenerator is based on the imagerasterizer I think so now I don't know if it's possible with one of these transformers.
I also tried to replace the intensity with the Z value, but that didn't work.
Does anybody know how to do it?
Best answer by takashi
Hi @koenvdw​ ,
According to the help, the RasterDEMGenerator should create a numeric raster with a single Real64 band always. I don't think you need to use RasterMosaicker and RasterInetepretationCoercer at all.
If you load the resulting raster with FME Data Inspector, how are its properties shown in the Feature Information window?
  • April 4, 2021
Hi @koenvdw​ ,
  • April 4, 2021
Did you use the ImageRasterizer?​ The resulting raster created with the ImageRasterizer could be RGB or RGBA color image.
You can just use a RasterDEMGenerator to create a DMS raster. No need to any other transformers.
koenvdw
  • April 7, 2021
Hi Takashi
Thanks for the help. I changed the workbench to this:
4
You were right. There is no need to use other transformers.
I thought I tried this first and I didn't get the result I'm getting now. I cleared fme cache and rebooted pc. Now it works... Maybe I did something else wrong the first time.
The only thing is I'm getting a bit of noise around the wall's of buildings. Is there a way to clean that up?
Example:
5
