How to extract layer names and each tables name related to each layer from mxd file
  • May 5, 2023
  • 67 views
gogopotter90
Forum|alt.badge.img+14
I have mxd file and I would like to extract layer names and each table names related to each layer
FME 2021
Thanks in advance
hkingsbury
Forum|alt.badge.img+67
  • May 6, 2023
You'd have to use python, see below for a pseudo implementation (taken from - https://gis.stackexchange.com/questions/150734/listing-data-sources-in-arcgis-map-mxd-without-opening-it)
mxd = arcpy.mapping.MapDocument(m)
                for lyr in arcpy.mapping.ListLayers(mxd):
                        for dirpath, dirnames, filenames in arcpy.da.Walk(MapList):
                            for filename in filenames:
                                desc = arcpy.Describe(os.path.join(dirpath, filename))
                                desc.catalogPath
                                desc.name
                                desc.dataType
gogopotter90
  • May 8, 2023
                                desc.catalogPath
                                desc.name
                                desc.dataType
Thanks for ur code ,
i have tried it and added in Python caller  the import modules and mxd path and csv path output but I got an error .it does not work with me .
hkingsbury
  • May 8, 2023
As I said, the above is pseudo code. It's a rough outline of what is needed.
If you're getting an error, its helpful to include what that is otherwise we have no idea whats gone wrong 🙂
