How could i change the line width at parameters in specific layer (Adobe spatial pdf feature writer ) without effecting lines width at other layers ?
  • August 27, 2021
  • 105 views
gogopotter90
Forum|alt.badge.img+14
when i change the Default line width to 0.6 in feature wirter ( adobe geospatial pdf in Feature writer ) ,i found it changes for all layers .
i would like to change only for one layer and others still has the same width of lines .
How could i achieve it ?
i need only to change paramter of width of lines in one layer without effecting other lines at other layers .
my workspace : i have different lines ,with different colors
and i would like to increase the width line with green color that i show in pdf output and others still have the same line width in pdf output .
Thanks in advance
FME 2018
PDF-Feature writer
Best answer by gio
Hi
You can use/set pdf attributes directly.
When yo set a pdf_line_width using for instance a attribute creator it wil override the defaultsetting.
You can see
You could to read the Readers and Writers document. PDF section.
gio
Forum|alt.badge.img+15
  • August 27, 2021
Hi
You can see
gogopotter90
  • August 28, 2021
Hi
You can see
Thanks for ur idea,it works great
