Converting dates read from Microsoft Sharepoint
  • January 3, 2023
  • 53 views
femo
The field i would like to convert looks like this:
datetime_sharepointLooking at the same data via the Sharepoint GUI, the visible date is 04.08.2021.
How can i convert from the date above to the data in the GUI. I have been told, that the sharepoint date is GMT +00, while the GUI date ist GMT +01
I have already tried various datetime functions, but so far without success.
Thank you for your ideas!
  • January 3, 2023
Try this expression in a DateTimeCalculator set to Advanced:
@TimeZoneSet(@TimeZoneSet(@Value(ASK),utc),local)
This will first parse the timestamp as UTC, then convert to local time.
I'm sure there are other ways.
