Microsoft SharePoint List Reader metadata
  • May 27, 2021
  • 40 views
Does anyone know if there is a way to extract metadata about a Microsoft SharePoint List? In particular, I would like to know the date each record in the list was last modified.
I am using FME Desktop 2020.1.1.1
Thanks
Best answer by nampreetatsafe
Hi @aquamarine​, try setting the Show All Fields parameter to Yes when either adding a new Reader or Updating an existing SharePoint List Readers. This should expose the Modified attribute for a list.
2021-06-02_0-33-09
nampreetatsafe
Forum|alt.badge.img+13
2021-06-02_0-33-09
  • June 2, 2021
@nampreetatsafe​  thanks that worked perfectly!
