Remove text wrapping
  • February 2, 2022
  • 118 views
boubcher
Forum|alt.badge.img+11
Hello guys
is there a way we could remove the waring in the text file that looks like this
test wrapin
and get it only in one line with "/"between each line value
the final result should get
P20201_WXL2EAO3AKAU/P20201_WXW2ECO1CVI6/[al/WX62D212NFU2
Thanks
Best answer by ebygomm
I think this in a StringReplacer with Regular Expression replace should work
(\n|\r)+
Match 1 or more line feeds or carriagereturns and replace with /
Forum|alt.badge.img+46
  • February 2, 2022
Do you know if the wrapping includes line feeds or carriage returns or both? If you turn syntax highlighting to FME in the text editor you should be able to see this
boubcher
  • February 2, 2022
@ebygomm​
thanks for your reply ,
we are dealing with a different doc
sometimes return, sometime both
  • February 2, 2022
(\n|\r)+
boubcher
  • February 2, 2022
(\n|\r)+
Yes it working
Thanks so mutch
