FME Desktop 2020: How to delete All layers (feature classes) available in the destination esri file Geoddatabase before writing on it from a workbench?
  • November 26, 2021
  • 44 views
jamal
Forum|alt.badge.img+5
For example, in the screenshot below, I wanted first to delete all layers that are available in the destination esri file Geoddatabase before writing in it
How this could be performed?
Clip_1242
Best answer by hkingsbury
In your writer (in the Navigator pane), set it to Overwrite Existing Geodatabase
hkingsbury
Forum|alt.badge.img+67
  • November 28, 2021
jamal
  • December 4, 2021
Thank you for the help. It works fine
Clip_1302
Clip_1303
