FME 2020: Which FME tool is equant to “Spatial Join” in ArcGIS?
  • February 3, 2021
  • 6 replies
  • 119 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out which tool is equivalent to “Spatial Join” in ArcGIS.
I’m aware of the “spatial filter” tool but appears not to produce the expected result as the block number is supposed to be transferred to each parcel
Clip_355
Clip_356
Clip_357
Depends on what you are trying do and the data input.
SpatialRelator will give you intersects, overlaps, identical, etc. like ArcMap.
In many cases you may be looking to fit not so perfect data on top of other data and you can use a PointOnAreaOverlay to bring the data together by converting your intersect layer to points, overlaying, and merging attributes.
After the intersect, use a FeatureMerger with the resulting intersect connected to the layer you want to attribute and you will inherit the values.
There's always 5-10 ways to do the same thing in FME and that's what makes it so great!
hkingsbury
Forum|alt.badge.img+67
  • February 4, 2021
second the PointOnAreaOveralyer approach. Use a center point replaced on the smaller areas (1,2,3...7,8) then the SpatialRelator and FeatureMerger as described above
jamal
  • February 4, 2021
What I wanted here is to transfer the block number to parcels that THEIR CENTROIDS LIE within the block boundary. This can be done with one tool in ArcGIS (Spatial join).
The output I’m expecting appears in the second screenshot as a field for the “blocknumber” is added to the parcel layer and thus each parcel gets block number it lies within
Clip_358Clip_356
jamal
  • February 7, 2021
The two fields (parcelnumber and blocknumber) are now available on the point layer. What I wanted is to transfer them to the parcel polygon layer.
How this can be performed?
Clip_361
hkingsbury
  • February 8, 2021
Clip_361
Use the PointOnAreaOverlayer, under attribute accumulation select Generate List On Output 'Area'. You'll then have a list of (the selected) attributes from the point layer
jamal
  • February 8, 2021
Thank you. I have already posted it in a new thread to better explain the issue
